RecycleBIM
Integrated Planning and Recording Circularity of Construction Materials through Digital Modelling
Start:
02/05/2022
Project duration:
36 Months
Consortium partners
  1. University of Minho (Portugal)
  2. Technische Universität Darmstadt (Germany)
  3. Universidade de Vigo (Spain)
  4. Stellenbosch University (South Africa)
  5. ACCA software S.p.A. (Italy)
  6. Südhessische Wertstoffrückgewinnungs GmbH (Germany)
  7. University of the Western Cape (South Africa)
  8. LEZAMA DEMOLICIONES S.L. (Spain)
  9. Lafarge Centre de Recherche (France)
  10. Newton (Portugal)
  11. Gaiurb EM (Portugal)
  12. Marta Campos – Architecture (Portugal)
EN
The project intends to make a multi-national and multi-stakeholder effort towards the creation of an integrated framework for circularity of raw materials of construction, leveraged on the wealth of information that is brought about by 'Building Information Modelling'.
The framework includes five main aspects:
(i) development of a new methodology of survey of constructions to-be- demolished, based on state of the art methods (e.g. handheld laser scanning) to allow semi- automated digital twins of buildings to be created at a controlled cost;
(ii)establish adequate BIM modelling rules (and information requirements) that allow the BIM model to host all the relevant information for the full deconstruction analysis, including health and safety aspects, deconstruction phasing/techniques and quantity take off regarding the materials available for reuse and recycling;
(iii) create an IFC-based tool for multi-criteria optimisation of deconstruction strategies and materials, so that designers of new construction, or planners of deconstruction of 'to-be-demolished' can have their BIM models analysed in a platform that manages an integrated multi-criteria optimisation procedure for deconstruction phasing and strategies, including LCA/LCC analysis (with distinct peculiarities when making Design for Deconstruction, or when solely planning the demolition of an existing building);
(iv) strategic and optimised use of recycled demolition waste in 3D printed concrete for local digital construction practice;
(v) make all the previous developments together with a specific set of tools for Municipalities to use in their process of issuing both deconstruction and newbuilding permits based on BIM models (openBIM), as to manage better focus in municipal approvals based on traceable data, and at the same time, keeping accurate records of material circularity at a local level (enabling global optimization strategies at municipal level).
IT
Il progetto intende compiere uno sforzo multinazionale e multi-attore verso la creazione di un quadro integrato per la circolarità dei materiali da costruzione, sfruttando la ricchezza di informazioni apportate dal "Building Information Modelling".
Tale quadro contempla cinque aspetti principali:
(i) sviluppo di una nuova metodologia per il rilievo del patrimonio edilizio oggetto di demolizione, basata su metodi all'avanguardia (ad esempio, scansione laser manuale) per consentire la creazione di gemelli digitali semiautomatici di edifici a costi controllati;
(ii) stabilire regole di modellazione BIM adeguate (e requisiti informativi) che consentano al modello BIM di inglobare tutte le informazioni rilevanti per l'analisi completa della demolizione, ivi inclusi gli aspetti di salute e sicurezza, fasi/tecniche di demolizione e computo delle quantità relative ai materiali disponibili per il riuso e il riciclaggio;
(iii) creare uno strumento su base IFC per l'ottimizzazione multi-criterio di strategie e materiali di decostruzione, così da consentire a progettisti di nuove costruzioni o smantellamenti, di analizzare i propri modelli BIM in una piattaforma che gestisce una procedura di ottimizzazione multi-criterio integrata per fasi e strategie di smantellamento, ivi inclusa l'analisi LCA/LCC (con peculiarità distinte quando si effettua il Design for Deconstruction, o quando si pianifica esclusivamente la demolizione di un edificio esistente);
(iv) uso strategico e ottimizzato dei rifiuti di demolizione riciclati in calcestruzzo stampato 3D per le pratiche edilizie digitali locali;
(v) realizzare tutti gli sviluppi precedenti unitamente a un insieme specifico di strumenti che i Comuni possano utilizzare nel loro processo di rilascio dei permessi di nuova costruzione e smantellamento basati su modelli BIM (openBIM), in modo da gestire meglio le autorizzazioni comunali sulla base di dati tracciabili e, allo stesso tempo, tenere registrazioni accurate della circolarità dei materiali a livello locale (consentendo strategie di ottimizzazione globale a livello comunale).
Convention ACCA 2024
